Hello, when I try to box-map a curtain wall in “Realistic” view everything seems to work fine but as soon as I lunch a render with vray a wrong uv is applied. Specifically, when exploding the curtain wall everything works well. Is there something that I am missing?
There are some missing textures in the file. Anyway, I see you are using an old VisualARQ version. We made some improvements in the last versions so please, update to the last one to check if this problem is solved: https://www.visualarq.com/download/update/.
Yes, you can create a custom profile using the _vaProfileFromCurve command:
Then, you can choose this custom profile in the list:
