Wrong print width - geometry inside block by parent, instance by layer
This does not work as expected.
Geometry inside block is by parent print width.
Instance is by layer and layer is set to thick line but line is shown like if it was fine
it works with hardcoded setting
Hi @ivan.galik,
I am unable to reproduce this in Rhino 7. Can you upload a file that isn’t working for you?
– Dale
oh i am sorry, this is my fault, I had two layers called the same way and i thought i was controlling one but it was the other. please you can delete this post it is irrelevant.
