Wrong Phase when adding Elements with Rhino.Inside.Revit
Hi, I’m getting an unexpected behavior when adding elements in Revit model with Rhino.Inside.Revit. They are created in a different phase than the active view phase.
Any hints on how to fix it? Thanks
I’ve also noticed that this behavior changed in more recent versions.
To get around it, I just edit the Element Parameter “Phase Created”, and use the required Phase as the input value.
Yes phasing changed in 1.6.
It use to add element into the Active View Phase, but since 1.6 it adds all elements into the last Phase of the project, no matter what View is active.
Active view may be arbitrary or you may be modifiing a Document that is not open into the UI.
If you need the previouse behaviour you can do like this.
Or shorter…
Or just converting from View to Phase
thank you Adam!
Understood, thank you Kike!
