Steps to recreate:
Draw 3 objects and place each on a different layer.
When selecting an object it show which layer it’s on in the bottom, this is great.
Now when I immediately select a different object on a different layer, it shows the current active layer instead of the layer of the object I just selected.
This continues showing me the wrong layer until I first deselect everything and then select an object again.
Rhino 6.25 & WIP 7.0.20140
Rhino 5.14 doesn’t have this.
pascal
(Pascal Golay)
May 28, 2020, 4:57pm
4
Hello - I cannot so far reproduce this here. Does this happen in any file? If not, please post an example.
Yes, happens in any file. Here’s a video showing me doing these steps. (Unfortunately apparently my screen recorder doesn’t seem to want to capture the bottom toolbar showing the behaviour, but I just want to make sure you’re doing the same as I’m doing):
pascal
(Pascal Golay)
May 28, 2020, 9:16pm
6
I think I am doing exactly what you are - can you post the output from Rhino’s SystemInfo
command?
Rhino 6 SR25 2020-4-23 (Rhino 6, 6.25.20114.05271, Git hash:master @ f35d7ded15ec317635ced435d8df84327397038d)
License type: Commercial, build 2020-04-23
License details: Cloud Zoo. In use by: siemen ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: SIEMEN-PC
Hybrid graphics system.
Primary display: Intel® HD Graphics 530 (Intel) Memory: 1GB, Driver date: 11-18-2018 (M-D-Y).
Primary OpenGL: NVIDIA Quadro M2000M (NVidia) Memory: 4GB, Driver date: 1-31-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 442.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-31-2020
Driver Version: 26.21.14.4223
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.25.20114.5271
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.25.20114.5271
Yes, I see the same as siemen when “Turn on control points when selecting a curve, light or annotation” is on.
Wow, nice one! I would have never found out it’s that specific setting that causes this.
siemen
May 29, 2020, 4:41pm
10
@pascal , do you manage to repeat this by activating the setting @cadmaster pointed to?
pascal
(Pascal Golay)
May 29, 2020, 4:44pm
11
I do indeed see that - thanks everyone.
RH-58812 Layer update fails if points are on
