Wrong Angle
Hi guys,
Not sure what is happening, I have 2 lines and calculating the angle in GH. When I check it in Rhino it is different. The angle should be bigger then 90 degrees. Any idea what I am doing wrong?
Angle Between Lines.gh (8.3 KB)
Thanks
these are the starting points of your Vectors:
this is the angle you are measuring:
Reverse A:
or swap start/end points of Vector A:
Thank you Inno. You are the best!
