Write Rhino Commands in Grasshopper
Thanks that works nicely I haven’t messed around with rhinosyntax lib much so I didn’t know if the grasshopper player would do stuff like that or if it required the specific get blocks. I still think it would be nice to just have this as a default block as I think using grasshopper player scripts to act on external files before bringing them into rhino or doing some sort of validation test of a set of models will be decently common use for this feature and this kind of thing just speeds up workflow.
Added to the wishlist at https://mcneel.myjetbrains.com/youtrack/issue/RH-61663
I probably won’t be able to get to this anytime soon so the python technique is a good recommended approach for now.
A post was split to a new topic: Run Rhino Commands from Grasshopper
GH_CMD
https://www.food4rhino.com/app/ghcmd
hello, is ‘Grab’ supposed to work if you are feeding Points to create a Crv (to grab the elbow points to move around) ? currently can’t get it to work. thnx!
Edit: never mind, figured it out !
