Write Python script in VS Code
Hello there!
I do not know if it might help but I developed a small connector from vscode to run live python scripts both in Rhino and Grasshopper, it’s called script-sync. It is only tested on windows but it should get you run quickly to execute python script components from vscode.
You just need to install the yak package and the vscode extension of script-sync(version 1.1.0), add a script-syncpython-component, press shift-F4 in vscode and it should work fine :slight_smile:
single_comp
scriptsync_gh
