Write bracket with textObject
i need to write _-textobject {test} , but after typing and put text in Cplan, { } is omited.
Hello- what font are you using? So far this seems to work OK here.
Ah yes, I see in the scripted version it fails. Thanks for the heads-up…
RH-66954 TextObject: No brackets in scripted version
@pascal @valibeigi.akbar I can get this to work by escaping the braces with a backslash: -_TextObject \{test\}
@pascal @pierrec char { in font F_adib is ش in RTL language. when i write { on keyboard, rhino produce 4 charachter except original charachter
F_ADIB.zip (24.2 KB)
