Wrap curves around brep
Hello, I’ve had a look around but can’t find an example similar to what I want to achieve. I want to wrap contour curves/combine curves around a brep. I got further than the below pic using boolean difference in rhino but would like to make it parametric. Attached is the .gh file. Many thanks.
huggy.gh (13.8 KB)
I’m not sure if this is what you wanted. If so, you can achieve it with the Contour.
About Contour Grasshopper Online Document
huggy.gh (10.8 KB)
What do you mean by this?
Also, in addition to @jessesn’s help, you can skip the loft-cap-boolean combo like this:
huggy.gh (33.9 KB)
Thanks so much!
perhaps instead of parametric, I meant procedural? I just mean I want to be able to adjust parameters before performing the wrapped curves, so using baked geometry in Rhino isn’t ideal.
Thank you! Perfect.
