Worksessions for OSX
Thanks Elijah. I get it! I’m sure we can get this fixed with your help. We just need to reproduce it. When you have time :slight_smile:
I’m seeing similar behaviour - it seems to be related to model size. If I create simple geometeries then there is no issue, but if the models start getting larger, I see the immediate crashes. I uploaded a bunch of crash reports when this happened (Not sure how easy it is for you to find those).
I also see the same issue when using the import function to import one large model into another (same files I am trying to use for WorkSessions)..
Hi -
Are you sending in the Rhino crash report or the macOS crash report? I’m only seeing reports from 2025 and 2024 from your the email address that you are using here on Discourse.
Please run the Rhino SystemInfo command and copy-paste its output here.
i was reporting via the Rhino Crash reporting dialogue box:
Rhino 9 SR0 2026-4-21 (Rhino WIP, 9.0.26111.12306, Git hash:master @ ee66d7adbde5fe887d823f2376a2f70bd3b998f2)
License type: Commercial, build 2026-04-21
License details: Cloud Zoo
Expires on: 2026-06-05
Apple macOS Version 26.4.1 (Build 25E253) (Physical RAM: 128GB)
Mac Model Identifier: Mac16,5
Language: en-CA (MacOS default)
.NET 10.0.2
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M4 Max
Studio Display (2560 x 1440 @ 60.00Hz)
Color LCD (1496 x 967 @ 120.00Hz)
LG HDR 5K (2560 x 1080 @ 60.00Hz)
GPU Vendor: Apple
USB devices
VLI Inc.: USB 2.0 BILLBOARD
Apple Inc.: Studio Display
Promise Technology, Inc.: TD-300
Realtek: USB 3.2 Device
LaCie: Rugged THB USB 3.0
SanDisk: Extreme Pro 55AF
Fresco Logic, Inc: Generic Billboard Device
LaCie: Rugged USB-C
SanDisk: Extreme Pro USB4
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_DarwinFoundation1.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswift_DarwinFoundation2.dylib
/usr/lib/swift/libswift_DarwinFoundation3.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswiftCoreMediaIO.dylib
/usr/lib/swift/libswiftCallKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/updaters/libAppleTconUARPUpdater.dylib
/usr/lib/updaters/libT200Updater.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/pharris/Library/Application Support/McNeel/Rhinoceros/packages/9.0/keyshot_studio/1.9.12/libsceneapi_wrapper_rhino.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/import_USD.rhp “Import USD” 9.0.26111.1002
/Users/pharris/Library/Application Support/McNeel/Rhinoceros/packages/9.0/keyshot_studio/1.9.12/KeyShotStudioRhino8Plugin.rhp “KeyShotStudioRhinoPlugin” 1.0.0.0
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_glTF.rhp “Import glTF” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ShrinkWrap.rhp “ShrinkWrap” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Grasshopper2Plugin.rhp “Grasshopper2” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_glTF.rhp “Export glTF” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_USD.rhp “Export USD” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_E57.rhp “E57 Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MPlane.rhp “MPlane” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Squish.rhp “Squish” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_M.rhp “Import_M” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_X.rhp “X Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STL.rhp “STL Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_STL.rhp “STL Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_Points.rhp “Points Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X.rhp “X Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_Points.rhp “Points Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 9.0.26111.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 9.0.26111.12306
/Applications/RhinoWIP.app/Contents/PlugIns/ExportNavisworks.rhp “Navisworks Export” 9.0.26111.1002
Hi -
But are you using a different email address when sending in that report?
As Dan requested earlier in this thread, please upload the files that consistently crashes on your machine from https://www.rhino3d.com/upload/
I used the link to upload the two files I was using. I have a lot of plug-ins. not sure if that has anything to do with this but I can send that info - just tell me how to list them
Excellent. I see the files. Thank you for these :raising_hands: . I will give this a try very soon and report back.
Yes, understanding what plugins you have installed may be quite important in this case. Please run the SystemInfo command in Rhino and copy/paste the output here (or PM it to me if you prefer - though it should not contain anything sensitive).
Rhino 8 SR30 2026-4-13 (Rhino 8, 8.30.26103.11002, Git hash:master @ 3ad61623b0ac4561e2f13265580c56a9f50596d8)
License type: Commercial, build 2026-04-13
Apple macOS Version 26.4.1 (Build 25E253) (Physical RAM: 24GB)
Mac Model Identifier: Mac16,8
Language: en-US (MacOS default)
.NET 8.0.14
Graphics processors
Apple M4 Pro
Color LCD (1512 x 982 @ 120.00Hz)
HP 2311xi (1920 x 1080 @ 60.00Hz)
DELL P2717H (1920 x 1080 @ 60.00Hz)
HP 2311xi (1080 x 1920 @ 60.00Hz)
GPU Vendor: Apple
USB devices
DisplayLink: Plugable UD-ULTC4K
Seiko Instruments Inc.: Smart Label Printer 620
Silicon Laboratories: EFM8 HID ISP
3Dconnexion: SpaceNavigator
Bluetooth devices
None
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/Users/eliporter/.rhinocode/py39-rh8/libpython3.9.dylib
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_heapq.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_ssl.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/libssl.1.1.dylib
/Users/eliporter/.rhinocode/py39-rh8/libcrypto.1.1.dylib
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_socket.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/math.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/select.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/array.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_struct.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/binascii.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/zlib.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_bz2.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_lzma.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/grp.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_bisect.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_random.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_sha512.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_datetime.cpython-39-darwin.so
/Users/eliporter/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_csv.cpython-39-darwin.so
/Users/eliporter/Library/Application Support/McNeel/Rhinoceros/packages/8.0/DOCOgrade/8.0.0-test.5/net7.0/DOCOgrade.rhp “DOCOgrade” 8.0.0.0
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.30.26103.11002
I just noticed these are V8 3dm files. (That’s fine, we ought to be able to make that work, I think). However, this SystemInfo is from V8 as well. Can I please see the results of SystemInfo from the V9 WIP you’re running?
.NET 10.0.2
Graphics processors
Apple M4 Pro
GPU Vendor: Apple
USB devices
Bluetooth devices
None
None
Third party plugins
Thank you! Looks like you do not have any third-party plugins installed for the RhinoWIP, which is good, that simplifies things. (I do notice you seem to have a lot of external displays connected. That might be an issue, but let’s come back to that later once we’ve explored more).
I can’t currently reproduce yet (I’m likely missing some details). Here’s what I did:
  1. Launched RhinoWIP 9.0.26111.12306 (same version you are using)
  2. Opened your provided [filename]_1.3dm.
  3. Ran the Worksession command and selected the Attach button.
  4. Attached your provided [filename]_2.3dm.
Both files are open and working as expected. I panned around a little and made some changes to the active file and it worked.
If I’m understanding your report, after step 4 above, you crash? Or is there something else you do to make it hang and require a Force Quit (which is I believe what you are reporting)?
it closes and give me the “Rhino has crashed” alert the moment I attach the second file. I just disconnected from all the monitors and tried again and it crashed. I opened WIP again, closed Rhino 8 (which has always been open at the same time in the past) and it crashed when I tried to attach. - I have the problem report generated for Apple if that helps
Problem report.txt (223.0 KB)
Just tried something - I was using linked blocks. Occurred to me that worksessioning and linked, referenced blocks might not play well together. I eliminated all the linked blocks and worksession worked fine - or at least didn’t crash immediately.
Update: after I got a worksession to at least not crash I tried to switch between the two files in the worksession manager and it crashed immediately.
Update 2: I made some simple files with only some curves and worksessioned between those ok. Then experienced an instant crash when I tried to attach one of the floor plans I sent you.
Update 3: So I had a worksession open with the two floor plans. I went to open a third file (separately) and it crashed instantly.
Interesting. I wish we could reproduce this. I wonder if it’s not crashing on my side because it cannot “see” the linked blocks.
Update: I added a linked block to your second file and I still couldn’t reproduce the crash.
Elijah-
We figured it out. This should be fixed in the upcoming RhinoWIP (this week if all goes well). Stay tuned.
-Dan
you guys are the best - thanks!
Hey Elijah-
We just put out another RhinoWIP where these crashes you’ve been seeing ought to be fixed :crossed_fingers: but I would appreciate you giving it a try.
-Dan
Thank you! So I fired up a worksession with the two files I sent you (with the referenced/linked blocks attached). It let me at least open them. I didn’t work on the files at all for 15 minutes. When I went back to rhino they just closed without me doing anything. Will do a little more experimenting. Really want this to work. Moved from PC to Mac recently and the lack of worksessions has been a bigger headache than I anticipated.
Well that’s progress at least :laughing:
Can you please expand on that a bit more? Was the RhinoWIP still running, or had it crashed?
WIP crashed - just shut off. I really just switched to rhino full screen and it crashed. There was the apple crash report feedback interface.
