Added:
When Worksession
is started using the File drop down menu they system tries to execute an unknown command “Browse” after -Worksession has completed and closed. Obviously this should not happen. I tried starting several other commands using the File drop down menu and all completed and did not try to start an unknown command.
Although it is only a nuisance it should be put on the heap to be fixed. The fix should be simple - my guess is some extraneous lines in an script or similar.
To replicate the bug:
Start Worksession
command using the File dropdown menu
Save in Worksession
Result in command history:
Command: _-Worksession
_Save
Worksession file successfully written as E:\Temp\WSExample.rws
_Browse
Unknown command: _Browse
_Enter
Start Worksession command by typing Worksession
Save in Worksession
Command: -Worksession
Save
Sample files:
WSExample.rws (257 Bytes)
Simple01.3dm (1.5 MB)
Rhino 7 SR17 2022-3-22 (Rhino 7, 7.17.22081.03001, Git hash:master @ e429706ef2564517d368a193809c158c4fe9e7b3)
License type: Commercial, build 2022-03-22
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 12-29-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.09
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-29-2021
Driver Version: 30.0.15.1109
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.17.22081.3001
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.17.22081.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.17.22081.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.17.22081.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.17.22081.3001
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.21.831\SectionTools.rhp “SectionTools”
