Worksession - Status - Update Available?
This may or may not be V9 Beta specific.
I’m a single user, not sharing files with anyone and all files are stored locally. I use Worksession to use files for reference.
Worksession panel - Status - “Update available” appears occasionally when openning a worksesseion, or when changing the active file. It vanishes after a few seconds to maybe thirty seconds.
What does it mean? I don’t recall seeing anything like it before, and I’ve been using Worksession since V5.
Rhino 9 SR0 2026-8-18 (Rhino 9 BETA, 9.0.26230.12303, Git hash:master @ 6f106e5b835d5e5898cf05bb9cc1139943a5666f)
License type: Commercial, build 2026-08-18
License details: Cloud Zoo
Expires on: 2026-10-02
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 10.0.11
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 6-11-2026 (M-D-Y). DirectX(11)
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\ClippingBox\0.5.3\ClippingBox.rhp “ClippingBox” 0.5.3.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26230.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26230.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26230.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26230.12303
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26230.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26230.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Hi David,
The Status column in the new Worksession panel has three values, Active, Update available, and File not found. “Update available” means the panel’s periodic check thinks the file on disk is newer than the copy loaded in the worksession, and the refresh button on the panel reloads it.
The reason you see it flash briefly when opening a worksession or changing the active file, even as a single user with unchanged local files: those operations write and re-read the member files themselves. Switching the active file saves the outgoing model and re-reads the members from disk, so for a moment the panel’s check is comparing against files that are mid-write, and it reports an update until the next check cycle clears it. i set up a two-file worksession here and confirmed the status tracks real file changes correctly and clears on reload, so the transient you’re seeing is cosmetic, your files are fine.
It probably shouldn’t show at all during operations Rhino itself initiates, i’ve noted the panel behavior with the developers.. RH-98046
