Worksession - Layer vanishing when file is not active
Worksession in V8.
Layer becomes invisible when file is changed from “Active” to “Attached”.
File is too large to upload.
File “Bain” is active file. File “Contours” is attached. All layers are visible.
Swap files so “Contours” active and “Bain” is attached. Layer Meshes > Analysis vanishes.
Swap back so “Bain” is active and “Contours” is attached and the layer reappears.
Repeatable. Also occurs with other models with same or similar layer structure.
Any ideas on how to fix?
Rhino 8 SR33 2026-6-11 (Rhino 8, 8.33.26162.14541, Git hash:master @ ef26a88fdc37234b688cfa11d5906089deb5be0c)
License type: Commercial, build 2026-06-11
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.28
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 3-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.79
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-4-2026
Driver Version: 32.0.15.9579
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.33.26162.14541
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.33.26162.14541
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.33.26162.14541
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.33.26162.14541
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.33.26162.14541
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.33.26162.14541
Found the cause. Worksession does not show layers without objects for attached files. Had not noticed that before.
