Worksession curves as input?
Hello!
I’d be useful if certain VA commands would take objects in worksessions as input.
E.g. just wanted to use vaSlabSubtract, and tried to pick a curve in a worksession - does not work.
Any Rhino command takes objects in worksessions as input, which is their great advantage. Would it be possible here, too?
(This is something different and simpler than the problem of VA objects over different worksessions, as was discussed in the past.)
Thank you!!
Hi Eugen,
All right. When VisualARQ supports work sessions we will take into account this request.
