Is there a way to work with picture frames with rhinocommon? I would like to be able to ask the user to create one from a jpg file and then store this in a variable and then be able to manipulate its position and orientation.
I don’t see a rhinocommon command for inputing a picture frame, so I’m guessing I will have to script this from the command line. But what about the variable that holds the picture frame? I tried just an objRef, but that seems to only hold the surface information, not the picture too.
When I use that I get the error:
reference to a non-shared member requires an object reference
I must not be using it properly…
I didn’t see it in the rhinocommon namespace guide, maybe there is a more up to date one? The one I am using is here: http://4.rhino3d.com/5/rhinocommon/
The code is below. I just seems like my rhinocommon doesn’t have the function AddPictureFrame. I’m noticing that while I have the latest service release, there is a new ‘candidate’ version. Would that help?
Thanks,
Sam
Imports Systems
Imports System.Windows.Forms
Imports Rhino
Imports Rhino.Commands
Imports Rhino.Geometry
<System.Runtime.InteropServices.Guid("1cca23b9-bfef-4897-b2bf-483c254ea3ea")> _
<Rhino.Commands.CommandStyle(Commands.Style.ScriptRunner)> _
Public Class Testing
Inherits Rhino.Commands.Command
Private Shared m_thecommand As Testing
Public Shared ReadOnly Property TheCommand() As Testing
Get
Return m_thecommand
End Get
End Property
Public Sub New()
m_thecommand = Me
End Sub
Public Overrides ReadOnly Property EnglishName() As String
Get
Return "Testing"
End Get
End Property
Protected Overrides Function RunCommand(ByVal doc As RhinoDoc, ByVal mode As Rhino.Commands.RunMode) As Rhino.Commands.Result
Dim dialog As New OpenFileDialog()
dialog.Filter = "Image Files|*.bmp;*.gif;*.jpg;*.jpeg;*.pcx;*.png;*.tif;*.tiff"
Dim rc As DialogResult = dialog.ShowDialog()
If rc <> DialogResult.OK Then
Return Result.Cancel
End If
Dim filename As String = dialog.FileName
Dim corners As Point3d()
Dim res As Result = Rhino.Input.RhinoGet.GetRectangle(corners)
If res <> Result.Success Then
Return res
End If
Dim p0 As Point3d = corners(0)
Dim p1 As Point3d = corners(1)
Dim p3 As Point3d = corners(3)
Dim plane As Plane = New Rhino.Geometry.Plane(p0, p1, p3)
Dim width As Double = p0.DistanceTo(p1)
Dim height As Double = p0.DistanceTo(p3)
doc.Objects.AddPictureFrame(plane, filename, False, width, height, True, False)
doc.Views.Redraw()
Return Result.Success
End Function
End Class
Imports System
Imports Rhino
Namespace MyProject1
<System.Runtime.InteropServices.Guid("7a163de1-4bcf-4b06-8b03-5b3654b329e8")> _
Public Class TestC
Inherits Command
Shared _instance As TestC
Public Sub New()
' Rhino only creates one instance of each command class defined in a
' plug-in, so it is safe to store a refence in a static field.
_instance = Me
End Sub
'''<summary>The only instance of this command.</summary>
Public Shared ReadOnly Property Instance() As TestC
Get
Return _instance
End Get
End Property
'''<returns>The command name as it appears on the Rhino command line.</returns>
Get
Return "Testing"
End Get
End Property
End If
Dim corners As Point3d() = Nothing
Return res
End If
doc.Views.Redraw()
End Function
End Class
End Namespace
I got the new candidate version and it works now.
I need to translate and rotate the picture frame after it has been added to the document, but the function returns a GUID rather than geometry. What is the best way to do this?
The user needs to click on some points on the image to determine how it should be oriented, so I can only orient it after it has been added to the document. Any really quick simple way to do this?
Whoops, that was a dump question, all I had to do was use a transform on the guid…
One thing I just noticed was that transforms don’t work on point geometries, kind of reminds me of how you can’t do cage edit on points, while many times I have wished I could. Just a thought…
All my questions are answered for this thread, thank you kindly.
Sam
