@Gijs, is it normal that the generated bolts are not threaded yet?
IMO this adds useless complexity to a scene. Instead Iām adding a cosmetic thread only in the form of a curve.
I agree and Iāve noticed the helictical curve, but threads would be a nice option in the context of 3D printing. I often times generate a metric bold, scale it up, and use it as a base geometry for a printable screw connection.
For instance, the BoltGen add-on is nice, but has only imperial presets (I believe).
No this is not the case, metric also.
@Rhino_Bulgaria here is a slightly better version that adds the metric bolts you mentioned, and organizes them into the correct block item layers.
addBolt_v0.8.py (18.9 KB)
This works fantastic! Thank you for the effort to add these screw sizes! I like that it could orient the screw even on the surface of a round tube, for example, which is very important for me.
good to hear btw, if you need other lengths than the one specified, simply change this in line 117:
lengths=['12mm','16mm','20mm','25mm','30mm','40mm','50mm','60mm','70mm','80mm']
Oh, yes, I was just looking for a way to make M8x35 mm and was unable to do it through the Command line.
pls download the edited version above @Rhino_Bulgaria
btw2: if you normally use socket allen, then you might also want to change line 108 to:
bolttype= sc.sticky["bolttype"] if sc.sticky.has_key("bolttype") else 2
Yes, this is what I mostly use, however, sometimes I also need hex head screws, so I think that your script has me covered in all situations.
I think that your script deserves its own icon.
I donāt know if you intend to continue this project or not, but I have some suggestions/requests.
1- Adding nuts (DIN 934) and washers (DIN 125)
2- Change main layer name to āFastenersā
3- An interactive pop-up window other than the command line (I think this is more time consuming and more difficult than the other two).
btw iām using v1.0 (installed on PM)
Thanks! very useful!
How can I add M20? Thatās the one I use the most.
Cheers.
D
Would Rhino users be willing to pay for a plug-in that does this?
that looks nice @DanBayn
Only one way to find outā¦
if you are using the python script, you can quite easily adjust it to your needs. If you look into the script, you will find I am using key value pairs for all properties, with the M size as key.
You should add hole size and direction recognition and then it may worth enough to become a commercial product. My2cent.
If I understand you correctly, you would like to pick a hole and the appropriate size fastener and direction happens automatically? If so, thatās a good idea.
Yup!
Thanks for the suggestion.
