When making documentation and building descriptions it is very annoying that rhino doesnt have the option for a defined textbox that wraps text automatically. Would be great to have for building documentation.
As of right now, one has to press enter for a sentence break in order to stay within a frame. Then, if one wants to make changes to that text - one has to go through the entire text and readjust the text and sentence breaks. Its actually mindblowing that this hasnt fixed/added in Rhino yet.
Once you already have the text, its flexible. its more the need to have an empty textbox. I suspect a lot of architects, using rhino/visualarq, create a large amount of layouts for projects - i have scripted my own layout creation manager that makes a number of layouts by copying a template layout. But i still have to sit and manually create and shape textboxes for each layout. if you could have empty text boxes on a layout template, when you make copies of that layout, they follow. You then fill them out…its a basic concept but hard to explain - all the other 3d-modelling programs have this.
Se attached video of the many faults with the rhino text box
@Jens_Jacob_Melhus_J1 do you mean that the text box size should be customized and preserved regardless of the text length? I agree this would be useful, but a request for McNeel developers. We could implement this in VisualARQ, but this is something that should be integrated natively in the Rhino Text tool.
Gotcha, for titleblock information I would maybe recommend using Document User Text embedded in a block. You can setup the bounds of the text and then paste it into the Document user text block.
Yea for sure, it would basically have to be copy pasted into the box, not edited in that little Value panel. I use the Document User Text all the time but never for text that long.
