Greetings,
It would be great if functions could be added to the rhinoscriptsyntax library to return the location current of dimensions. I have put together an example of this using rhino common.
def AlignedDimension_Points(self,dim):
Get the end points for the extension lines,
text position and arrow heads.
Identify the type of dimension being used
Get User Text for dimension
Input Parameters:
dim = guid for an aligned dimension
Return:
Type - Identify the type of demension
AH1 - 3D [point] identifying the end of arrow head 1
AH2 - 3D [point] identifying the end of arrow head 2
EL1 - 3D [point] identifying the end of extension line 1
EL2 - 3D [point] identifying the end of extension line 2
TP - 3D [point] identifying the center for text position
if rs.IsAlignedDimension(dim)==True:
Type="AlignedDimension"
Dim=rs.coercegeometry(dim)
Plane=Dim.Plane
Text=Dim.Text
AH1=Plane.PointAt(Dim.Arrowhead1End[0],Dim.Arrowhead1End[1])
AH2=Plane.PointAt(Dim.Arrowhead2End[0],Dim.Arrowhead2End[1])
EL1=Plane.PointAt(Dim.ExtensionLine1End[0],Dim.ExtensionLine1End[1])
EL2=Plane.PointAt(Dim.ExtensionLine2End[0],Dim.ExtensionLine2End[1])
TP=Plane.PointAt(Dim.TextPosition[0],Dim.TextPosition[1])
Dimension=[Type,AH1,AH2,EL1,EL2,TP,Text]
return Dimension
return None
This works for linear dimensions and aligned dimensions, however I am currently unable to return information for the location of angular dimensions using python.
Thanks,
5chmidt
