Hi. I make use of the Makro editor to make Makro’s for repetitive tasks, and it works well, but I was wondering if there isn’t a way to simply record sequence of commands as you do it and place the command sequence directly into the Makro Editor.
There is a PLAY button in the editor, but no RECORD button?
eg. I would press record and then run through all the tasks with options etc.once and the Makro editor would then place each command or command sub option on a new line as I go until I stop the recording of commands.
I think this would allow users to make Makro’s much easier without syntax and spelling errors etc. - Michael VS
