WISHes EdgeSrf, Clipping Plane, dupedge
It’d be nice if edgesrf would not need to select edges one by one, but if it’s boxed as below, one click in the center would just do.
Another is for the Clipping plane to be able to be moved while sub-object selection.
Using clipping plane to get those hard to see edges are great, but would like to move it around so I can get all edges, or objects that are difficult to get.
For the Dupedge, I think this was up before, not sure where it went, would like chainedge(and not dupborder) as I don’t want other places to get curves which needs to be deleted later.
I answered that you can join - curve - chain and then select the edge. Is that good enough?
Right! Thank you.
Totally slipped…
