Hi McNeel
Since working on a larger project with Rhino I miss some functionality regarding layout management. The following list goes from simple wishes to more complex wishes that would help with managing layouts:
Ordering of the layout tabs via drag & drop instead of the clumsy Move & Copy window (has been wished in other threads as well)
A layout manager. When working with many layouts (20+, depending on resolution) the tab approach becomes unusable. There exists a basic layout manager (http://www.food4rhino.com/project/layout-manager), but it has several bugs that make it almost useless. This has also been wished before. Sorry for repeating.
A sheet Set Manager as found in AutoCAD (I know this is asking for a lot and does not really fit in the Rhino way of doing things) or some similar interface that would allow easier management of the layouts content. (Edit) Sheet sets would be groups of layouts. For the sheet set two main features come to my mind: 1. variables. e.g. text variables placed on the layouts that can be managed through one window. The variables should be freely assignable key, value pairs. 2. layout templates that can be setup with the necessary variables and loaded through the Layout Manager. Currently we do this through nested blocks in referenced files, but the setup is very error prone with new people not used to the setup.
Edit:
4. A batch print function, where I could select a sheet set and print all the layouts in this sheet set at once.
Thanks
