Is surface unrollable? The same check as the first stage of the unroll surface command.
Hi Brian- is this a command request or a RhinoScript/Python method request?
thanks,
Thanks Pascal, I see its in Rhinoscript,( Rhino.IsSurfaceUnrollable (strSurface)), so that will do just fine.
It may be useful to others as a command for quick checking where you think you are working on a developeable surface but you’ve nudged a control point a bit too far…
