I found this older discussion about true dimension chains, which was recorded as RH-38900 back in 2017: [Continued or Chain Dimension]
As far as I can tell, Rhino already has a reasonably efficient workflow for creating continued dimensions. A true multi-point dimension-chain object would mainly improve subsequent editing and maintenance.
I think this would still be a very useful improvement, particularly for large models and technical documentation.
Creation
- Define the dimension line position/offset.
- Pick the reference points to dimension.
- Finish the command.
The result is a single dimension-chain object containing all dimension points.
Current Rhino behavior: continued dimensions are separate objects and must be selected and edited individually.
Editing
- Add Point — insert another reference point anywhere in the chain, including at either end.
- Remove Point — remove any existing reference point and automatically merge the adjacent segments.
