Wish: Toggle between Object and Cplane Align
Would it be possible to add a toggle between c-plane and object align when dragging with the gumball?
Similar to Tab locking the direction or Option disabling the snaps during the command being active. For example hit command after you start the drag you switch to c-plane align from object align.
So start with a sub d point with snappy dragging and gumball set as align to object. Begin the drag in the direction you need, hit cmd which locks movement to its object axis direction of travel but allows snaps to the C-Plane of any other points you hover over. So this is similar to hitting tab to constrain the direction but to temporarily switch object snaps to C-Plane align.
Aside from building lots of guide lines, which isn’t ideal as every time you adjust the design you need to rebuild all the guide lines, is there a shortcut or way to do this?
The image kind of shows where I want to be able to snap to on the fly just without having to use guide curves. I think the toggle would be able to get me there.
I am not sure if I understand it correctly: Do you want to snap to point B instead of point A?
Yes that the logic. I would hover over the corner of that rectangle in this example while moving the point and be able to snap to B while travelling in the green axis direction.
Right now stops at a perpendicular point based on the object being moved axis (A in your image) Which makes sense. That’s how it should be for object align but I frequently want to move points along the object axis (green arrow in your image) but still get them to relate to CPlane snaps. (Point B on your picture.)
