this is a very simple example that shows my wish:
trimming or boolean operation on periodic surfaces ( with a seam) - the seam should not survive if possible.
left - the input object with badly placed seams
middle - the current result, the seams are inherited from the input
right - optimised seam position avoids extra edge in the polysurface (my wish)
my wish: operations should check wether an operation really requires to keep the seam - resulting in 2 faces. if the seam can be “trimmed / booled” away it should not survive, the seam should be moved before the operation is finished.
optional shrink trimmed surfaces.
i think this is some nice enhancement - similar to mergeAllPlanarSurfaces.
(I do not expect it in V9, but it would be nice for the polish-old-tools-birthday edition V10)
@Tom_P This is considerably more complicated for general geometries than suggested by your “very simple example” involving only spheres and planar surfaces. The question of when a seam can be removed from a portion of surface is interesting, and I’ve made several attempts to work it out. But it quickly becomes more complex than I have time for.
Perhaps a developer or someone else has some free time, but there are probably more pressing issues for the McNeel folks to resolve.
… I agree on this.
My wish is from a user point of view, not from a developer point of view.
… and I also agree, that my simple sphere-example might not catch all challenging special cases. (imagine some surface which is periodic in 2 dimension, a torus…)
this is an simple sample where the downstream workflow causes a bad mesh. (it s not a “half”-Cylinder, its >180 degree…)
for the same part the seam will cause issues for filletEdge
