It would be great if Rebuild could work on subselection of a curve. Both on single parts and multiple if connected or disconnected.
@pascal do you think that would be possible?
Hi Jorgen - I suspect it is possible because using the nestable SubCrv
command works in Rebuild
- but just to be sure, if there is a sub-object selected segment in a polycurve, do you expect that to follow the Delete Input setting? I guess I would, but that might complicate things if it needs to be stuck back into the polycurve.
@Holo - I say it will work - here is a quick and dirty test that seems to show it should work fine - a bit more typing to get UI and feedback but I’ll let Mikko do that in the real world.
@Holo - since I was fussing with it, I thought maybe rebuilding all arc segments in a polycurve would be a handy thing.
Degree 5 or 6, or Auto. Auto = degree 5 for 90 degrees or more, degree 3 for shallower arcs.
