would it be possible to use the Leader arrows settings instead of the Dimension arrows setting for radial dimensions (or is this already possible and I am not finding the setting)? Or even better, would it be possible to have additional setting options for the different dimension types? e.g. Radius dimension arrows, Angle dimension arrows, etc.
Please see the attached image. The Tick on the lower circle makes no sense (at least in the countries we are working in ).
In architectural drawing you would want to use the Tick symbol for linear dimension lines and the Arrow or Dot for radial and other dimensions. Currently I have to setup two different styles.
Thanks,
Silvan
