- Digit Scroller - in cases where sliders trigger a big calculation you can’t accurately set slider value, because it lags out. Digit Scroller is a good solution there.
- Data Dam - same as above, when sliders (even digit scrollers) trigger a big calculation, it is better to have data dam button there so you can let the change go through for calculation when user is ready with modifying the values.
Yup, the plan is to expose pretty much everything under the sun on the remote panel. Sadly this is not happening right now because it’s such a pain in the behind to publish controls to it.
