Wish: Polyline (Bothsides=Yes)
Just went to choose the “bothsides” option from command line of the standard polyline command and realized there is no such animal. I think that would be a very helpful location for this option.
I don’t imagine the Bothsides behaviour would persist, (although that’d be so rad). I can see it just bailing out of “polyline” and terminating after one click the same way you can right click and bail out.
_Polyline (…Bothsides=Yes…)
declan
you mean so you could draw a T with a polyline?
i don’t think that would work out properly.
can you post an example drawn with lines that you’d like to happen with polyline->Bothsides?
Hi Declan - can you give me an example of what this would do?
thanks,
Hi guys - I see it as functioning exactly as the Line (Bothsides=Yes/No) option in the command line. So:
User enters “polyline” into command line
polyline command starts
command line options are(PersistentClose=No), AND (Bothsides=Yes/No)
if Bothsides=yes,
User clicks start of polyline and, effectively the command switches to “Line (Bothsides=Yes)” and ends once an endpoint has been selected.
if Bothsides=No
User clicks start of polyline, and subsequent points as expected.
Even the Line (not Polyline) command lacks a mid-stream “bothsides” option.
dh
That would be very confusing, I don’t see why you’re not using the Line command.
The standard line command doesn’t have a “bothsides” option either. You need to drill down to the Line From Midpoint command. Obviously it’s not a big deal, just looking to improve workflow. If Line had a “bothsides” option that would be fine too.
dh
Hi Declan - Line, all by itself, has a pile of command line options, including BothSides.
sheesh, sorry, you’re right. I was seeing LineSegments (RMB on Polyline button) as the Line tool. I knew I’d seen a bothsides option somehwere, LOL.
Can you tell last night was a Rhino-all-night kinda night? Nothing to see here… Carry on…
As an aside - was Line ever RMB on the Polyline button? Like maybe V2?
I don’t think so, but it is not impossible… sieve brain and all. But I think it’s always been Lines.
Ok, weird. Brainfart. Changed my RMB here and all is right in the world. Thanks all.
