Wish: Polygonal Wireframe Display and Rendering Mode
I’d like to suggest an additional viewport display option: Polygonal Wireframe, applicable to SubD, NURBS, and Mesh objects.
The idea is to display the actual polygonal mesh rather than only the simplified surface or control structure.
The attached screenshots show the same model from the same viewpoint, illustrating the difference between the two representations.
I find polygonal wireframe particularly useful for evaluating surface deformation, curvature transitions, and mesh distribution during modeling.
It can also be valuable for design presentations, especially if the same representation could be rendered directly.
Ideally, this would be a display option with adjustable wire color, thickness, and mesh density, without requiring users to extract or convert geometry into separate meshes,
with hidden edges removed, rather than showing a full wireframe through the object.
3ds Max has both options available for more than two decades.
