Wish: Plant 2D/3D display as viewport property
Hello!
Could this
please be a per-layer-property (remembered per layer)?
Because in Layouts, some viewports/detail views (top, elevation, section) should be 2d only, others 3d (axos, perspectives…).
Similar to how VisualArq stores it’s level/section settings.
Thanks a lot!
Hi Eugen! Thanks for you request. You mean “per-VIEWPORT-property”, right?
This is planned, though not for the near future.
Hello! Yes. It should be remembered per view if these checkboxes are set or not.
Thank you!
Hi @Eugen, I inform you that in Lands Design 6 it is possible to set different plant 3D - 2D representations by viewport, as well as an option to synchronize the display mode in all viewports:
