Wish: Osnap enabled with gumball manipulation[Solved]
Wish for using the gumball manipulation, for example X-Y,X-Z,Y-Z plane icon, to also support Osnaps. As well as X,Y,Z direction.
Snapping at the gumball center.
(useful for moving points or lines)
Hello - this has not changed from V5, you can set the Gumball as ‘Snappy’ or ‘Smooth’ , using the GumballSettings command, the context menu, or the Gumball pane menu.
Thanks! changed to solved.
@pascal For the snappy, is it possible to set the Gumball center as the snap point?
Currently the object center/and the object shifts to the mouse cursor and feels a bit weird when just trying to move without the osnap.
Hello - I’m not sure if I follow - what do you mean by “trying to move without the osnap.” ? Do you mean, the gumball should behave like a smooth gumball if there are no active snaps?
@pascal
Attached video screen capture.
First movement with the X-Y red-green crosshair the dragging is done at the cross hair.
Next is with the snappy on.
This time when trying to move with the X-Y red-green crosshair, the center of the object/center of gumball moves to the center of the mouse click instantly when dragging. Like a little jump.
->so, there’s a little bit of instant-shift everytime red-green crosshair
-> I understand if the Alt key is pressed or Osnap is ON, and that shift happens, but
even with Osnap off, is Snappy is selected that shift occurs and feels a bit weird.
https://aws1.discourse-cdn.com/mcneel/uploads/default/original/3X/2/2/22242dd5b96a90b097692b5b913e33711d06d701.mp4
