Wish: Option to break editing linked block
I just had a “crash/hang/bug” I have not had before in all these years using Rhino 7, and that was that double clicking a linked file did NOT open a new instance of Rhino. So this might be a one in a million issue, but none the less interesting enough to report.
Maybe there should be an option to actually click the “x” in the upper corner to cancel the block edit link. (Right now that x serves no function) This would need a new pop-up to inform of the consequences and that if the other file (linked block) finally opens and is saved it has to be manually updated.
I think a feature to break the waiting could be good anyway actually, somethimes it would be nice to be able to open the linked block in a separate Rhino and still navigate the main file.
I killed Rhino through task manager and didn’t loose much, but maybe an autosave should be stored prior to opening linked blocks too. This could happen in parallel so it doesn’t waste time.
PS! Task manager shows two rhino’s running… but no way to view the second instance.
Hi @Holo,
I could use a few things:
  1. Your SystemInfo.
  2. If it happens again, make a dump of the second Rhino.exe before ending it (Task Manager › Details › right-click › Create dump file).
Thanks,
– Dale
