Wish: MoveTargetToObjects to work with Grips as well
#1
It’s probably scriptable right now, but would be great if the actual Rhino command could do it on its own.
(Pascal Golay) #2
Hi Jarek - It is probably scriptable - but just -ViewportProperties _Target should help too. Making grips behave more like real objects is on the pile, but I do not know what the near term prospects are for that.
Thanks Pascal - using it so often (MaveTargetToObjects command) that don’t even think about it and many times doing so with grips selected with no luck. Will make a scripted version, but in a long run would be great to have it in command.
-jarek
#4
If anybody is interested, here is the solution. Script attached, and a compiled plugin that adds a ‘MoveTargetToObjectsAndGrips’ command. Should work with objects, grips and objects and grips mix.
-jarek
DIG.MoveTargetToObjectsAndGrips.rvb (1.9 KB) MoveTargetToObjectsAndGrips.rhp (9 KB)
