Wish. More commands to work with block's geometry
Hi All,
Imagine having a surface as a part of block’s geometry. I made some trials with some commands and found that some are working with sub elements of the surface and some not.
Here are some results (again, I’m talking about edges of a surface in a block):
  1. BlendCrv is working with surface edge selection.
  2. Extend is working while picking the surface edge.
  3. MatchSrf is not allowing to pick a surface edge to match to the surface in a block. (My most desired one).
  4. Sweep1 doesn’t work with edges as a rail input, but works as a profile input (that’s confusing, right?). And it works with curves from a block both ways.
  5. DupEdge works with surface edge.
My question is, could we have more consistency with all this? I would prefer to expand a range of commands which support the surface edges in a block as an input.
Sorry if I missed a topic, was not able to find.
Hello @wim ,
Could you please check if we already have such YouTrack requests?
Hi @wim and @stevebaer ,
Sorry for bumping the topic. Do you have any comments on this?
I would appreciate seeing a Youtrack with such request.
