Would be good to be able to save some presets for the meshing options.
I work with many different size object and purpose, so would be good to be able to save custom presets.
For example If I do rendering I need different option compared to the 3D printing.
If I print big object I use different properties from small objects, If I print with different printer type…
Thanks.
Riccardo
Yes please!
It’s a wish that has come up many times in the past and much like DXF/DWG export schemes this would make our lives a lot easier.
-Willem
Yeah… that is a loooong time wish and an obvious one. There is an ancient wishlist item from 2006, and I am sure I added one at least a hundred years ago before I was even in Seattle. I’ll nudge… I think I was chatting with, maybe, @dale Dale Fugier the other day about this.
Ohhhhhh! Yes please
Yes this would be very useful!
Norbert
+1. Accessible both from General options and object-level meshing. Would be great.
@pascal, if there isn’t anything on YouTrack, can you add something?
@dale -I found another, more recent one - http://mcneel.myjetbrains.com/youtrack/issue/RH-7573
