Wish: Level Locking – Keep Lower Levels Visible but Locked
When working on a building level, I find it useful to keep the lower levels visible as references. However, having their objects remain editable creates a risk of accidentally selecting or modifying geometry belonging to another level.
I would like to propose a Level Locking mechanism, independent of level visibility.
Proposed behavior:
  • The active level remains visible and editable.
  • Lower levels remain visible but locked by default.
  • Higher levels remain hidden, as they are now.
  • Each level has a Lock/Unlock control in the Levels panel, allowing users to explicitly change its editability without affecting visibility.
  • Locked objects remain available for Osnap.
Sub-level behavior:
Locking and unlocking should respect the level hierarchy, with changes propagating only downward:
  • Locking or unlocking a parent level should also lock or unlock all its sub-levels.
  • Locking or unlocking an individual sub-level should affect only the objects associated with that sub-level, without changing the lock state of its parent or sibling sub-levels.
Implementation:
I believe this could be implemented elegantly using the explicit Building / Level object association I proposed in my earlier wish, [Duplicate Level – Option to Include Objects].
The same underlying association could support both features without requiring users to organize their Rhino layers separately for each building level.
I believe the same principle should apply to locking: **level and sub-level relationships should be respected independently of their geometric elevations.
This is closely related to the level hierarchy behavior discussed by Gabriel in [Level double-click visibility should respect Sub-level hierarchy]. Although his discussion focuses on visibility, the same hierarchical principle should also apply to locking.
A simple Lock/Unlock control in the existing Levels panel, similar to Rhino’s Layers panel, would provide a straightforward and efficient workflow (see UI mockup below).
One important aspect I would like to emphasize is how this affects larger, multi-level projects.
When switching to another level, I would expect to have a safe editing context. However, objects from other visible levels remain selectable and editable, meaning that even a simple window selection can accidentally include geometry from other floors.
With many levels and sub-levels, manually managing their visibility just to prevent accidental edits becomes increasingly impractical.
Changing the active level should not require manually securing the rest of the building before editing.
Hi @badileanu thanks for this suggestion. We will consider it for future versions.
As an existing related feature (just in case others see this post and are not aware of it), you can activate the plan reference view (from the Level Manager) to see the plan view of levels, as a locked 2D drawing, projected on top of the current Level.
Level Manager Level Reference Plan 400
Thanks, Francesc.
VisualARQ already hides upper levels when working on a lower level. I believe lower levels should receive the same attention, remaining visible but locked by default.
The Plan View Reference is useful, and I don’t necessarily need a separate Lock button. However, as my test shows, when working on Level 01, objects belonging to Level 00 remain selectable and editable, even with Plan View Reference enabled.
The important thing is to keep the actual lower-level geometry visible and protected from accidental editing, ideally by default.
Is this simply a missing feature, or a limitation of VisualARQ’s current object-to-level association architecture?
A wanted to ask earlier fot this - I used reference view few times but did not complete work for me. I now did not recall why, but I needed to turn whole level ON (not just overlay) and go to wireframe to see some objects. I assume that this reference view only display sectioned geometry? It does not show complete floorplan, but only section parts, is that correct?
I have some regards about this. Locking the lower levels automatically when doing a double click on a level might make sense when working in plan view, but in the Perspective view it would be confusing, and maybe annoying. And having a different behavior of the double click on a level depending on the viewport would be confusing too.
Locking/unlocking levels is simply a feature that has not been implemented yet.
That’s correct. It only shows the plan view representation of VisualARQ objects. It doesn’t show objects in projection or the Rhino geometry in section (unfortunately).
Thanks for clarifying, Francesc.
I understand your concerns about automatic locking, and I can live without that behavior.
However, in my opinion, the ability to manually lock/unlock levels is essential for a professional BIM workflow, especially in larger, multi-level projects.
I found that this exact functionality had already been [requested back in September 2021], and the request was confirmed as added to the wishlist at the time.
Five years later, is there any concrete plan to implement level locking, and when could we realistically expect it?
I can’t provide a reliable timeline for this feature at the moment. We prioritize development based on several factors, including the number of user requests, the time and effort required for implementation, and whether alternative solutions or workarounds are available.
We certainly agree that adding the ability to lock levels would be a valuable improvement. However, including this feature in VisualARQ 4 might mean postponing another useful feature that other users have requested. It’s always a matter of balancing priorities to deliver the greatest value to our users.
I must admit this isn’t the answer I was hoping for,
but thank you again for your reply, Francesc.
One more question, Francesc: does VisualARQ expose an API that would allow a third-party Rhino plugin to extend the existing Levels Manager UI, for example by adding a Lock/Unlock control for each level?
I’m considering implementing this functionality myself, but I’d prefer to integrate it directly into the existing Levels Manager rather than create a separate interface.
Hi @badileanu there’s an API with some functions for creating buildings and levels (we are expanding these functions), but none for locking objects in a level, since this is a missing feature in the program.
This GH script can help you in this purpose: https://www.food4rhino.com/en/resource/select-objects-level
It lets you select objects by Level, so later on you can lock them.
Thanks, Francesc, for the clarification and the GH script reference!
