Wish: Layout names allow text fields
or is there some algorithm that does this?
Layout names allow text fields like that:
And that when printing in PDF it is saved with the name of the sheet that is registered in the layout
Hi @miguelayora3,
In Rhino 8 sr6 Release Candidate you can write a PDF to individual sheets and use the name of the Layout or other options when you Print with the Rhino PDF printer.
If you do not have the Update Frequency set to release candidate, and Check for update.
You can do it in Options → Updates and Statistics on Windows.
Rhino → Settings → General on the Mac.
Let us know if this helps.
Sincerely,
Mary Ann Fugier
