Hi Dale Lear
My important wish is InterpcrvOnSrf hooked to the history.
It’s possible?
Ciao Vittorio
Vittorio,
Have you tried the Curve on Surface Plug-in for Rhino 5 http://wiki.mcneel.com/labs/curveonsurfacev5 ?
It allows limited point editing, but the history is pretty easy to break. I like having both the plug in and the regular version of Interpolate Curve on Surface, as sometimes one will work better than the other.
Both of these could use a tune-up, as they often insist on taking a long route instead of the shortest route between two points, or refuse to cross the seam in a closed surface.
No, it’s not.
Greg wrote the built-in command and Dale wrote the plugin version
Hi Vittorio
I’m assuming you want the curve to be automatically updated if you edit the surface. Is this correct?
@GregArden @lowell I’ve created http://mcneel.myjetbrains.com/youtrack/issue/RH-32217 so we can look at this. Lowell I assigned the bug to you since you’re the History expert.
– Dale Lear
Yes , you understood perfectly.
Ciao Vittorio
