I would like to suggest integrating a render history viewer directly into Rhino’s existing Render Window, a simple scrollable list with thumbnails and relevant data.
The idea is simple: display a small, scrollable panel with thumbnails of previous renderings alongside the currently selected image.
Users should be able to:
Switch instantly between renderings by clicking a thumbnail or using the Up/Down arrow keys after selecting an image.
Preserve the same zoom level and pan position when switching images, making visual comparisons easier.
See basic information for each rendering, such as date, time, rendering duration, and resolution.
Access previous renderings after reopening the Render Window, whenever the saved images are still available.
Rhino already saves previous renderings, but accessing and comparing them is not as convenient as it could be.
The key point is accessibility: the history should be part of the existing Render Window, not a separate viewer or dialog.
This would eliminate the need to manually save intermediate renderings just to compare results, making the iterative rendering workflow much more efficient.
