Since it is impossible to duplicate Tree Branches that contain Model Objects using the Group and Ungroup components — and duplicating Tree Branches may require replacing the path names (see below) — could the components be made to work with Model Objects?
The groups are rather insightful, because it lists numbers of items, which makes it easier to spot whether the duplication is as expected. This is especially the case when it is mostly about matching up User Text attributes.
Compared to a Duplicate Data > Partition List (which may have or may not have the right order).
Alternatively, it is possible to duplicate Tree Branches by duplicating their paths and using the renumber option on Tree Branch, which introduces less possible user errors, but then the data paths may need to be replaced/matched. This is therefore (much) more involved.
