Hi, could some one help I’ve used SynchronizeRenderColors “rhino for mac” command on my model which did as expected but i now want to override or turn off the command but I can’t find a way, which ever way I try to change one rendered layer the others obediently Synchronize which I no longer require. any help appreciated. Regards
Hello - you should be able to just assign all objects to use Layer materials in their Properties. (that’s the default setting for new objects) You should be able to do this for multiple objects at once.
Hi Pascal
Thanks for getting back to me, I managed to resolve it, Using the drag and drop in the materials panel once i had created a new material and picked the colour i could drop it on to 1 or multiple objects and it would work.
but if i selected an object either in or out of the materials panel and changed the colour it would change all my layers. is this the expected result ?
regards
Quinn.
