Wish to be able to use a surface edge to flow from, for a surface used as input, for the flow command.
Does that make sense?
Hello - surface edges are accepted as input to Flow. If you want to use an edge from a surface that is being flowed then duplicate the edge first - is that what you mean?
Yeah exactly - I guess maybe it doesn’t make sense as it’s sort of implied that you wouldn’t be able to see the edge you’ve highlighted.
