If I were to:
- Move an object
- Delete an object
- Select another object and use the last command shortcut (RMB or Enter), the Move command is activated.
The delete command is ignored by the last command shortcut. As is a limited number of other commands. Can BringViewportToTop be added to that list? It’s a minor thing, but it gets me a dozen times a day.
I work in full screen perspective and use the MMB popup menu to switch viewports, often repeating the same command (move, scale, etc.) but from a different perspective.
