Instead of having the Set… button, just apply its function when an item of Set direction by is chosen. If the function is canceled, revert Set direction by to its previous item.
I’m with you.
The set option should be used to change the "custom direction " only.
If I select World Z or View Cplane it should be automatic.
+1 fo me
