Would it be possible to edit the values of the keys for DocumentText fields in a dialog box as opposed to command line only? Editing multiple DocumentText fields (20+) in my title block via the command line can be a bit of a pain and it would be a lot easier to simply select the value of a key in the Text Field dialog box and change it there. Also, in that dialog box their is the plus sign to add a new key but no apparent way to delete an existing DocumentText field key so if you make a mistake on the new key name you’re stuck with it. So to sum up, my request is to be able to edit and delete DocumentText keys and values in the current dialog box for Text Fields. Thanks.
