When duplicating a level in the Level Manager, VisualARQ currently copies only its settings, not the architectural objects.
In multi-storey buildings, structural elements, walls, slabs, and often windows are repeated across floors, even when layouts differ. Being able to duplicate an entire floor would provide a consistent starting point, allowing users to modify only what differs.
I suggest adding an Include Objects option to the existing Duplicate Level command, while preserving its current behavior when disabled.
The duplicated objects should be placed at the new level elevation, maintaining their relative positions and parametric relationships.
Since VisualARQ already supports level constraints, perhaps this mechanism could also help identify which objects should be duplicated.
Hi @badileanu I take note of this request. We will study it. Meantime you can simply do a Window selection from an Elevation view, and copy all the desired objects from one elevation to another.
Window selection is actually how I’ve been copying floors so far, but it’s not as straightforward as it may seem.
A simple example is a slab. VisualARQ places slabs at the bottom elevation of the current level by default.
When selecting an intermediate floor in an elevation view, the selection can also include the slab belonging to the floor above. To avoid this, I would need to manually deselect the slab from above.
And this is just one example. In more complex models, manually selecting the correct objects becomes increasingly difficult and error-prone.
That’s precisely why I suggested an Include Objects option in Duplicate Level: to duplicate the objects associated with a level without relying on geometric selection workarounds.
As illustrated below, Window selection works for the upper floor, but when selecting an intermediate floor, it also includes the slab belonging to the floor above.
Everything has its pros and cons. We need to study carefully how to handle this. Right now, if you duplicate a level, it is generated in the same elevation as the original one, so we should avoid this if a copy of the objects is included . Also, you may want to control what you copy from the level and what not, since you may have hidden objects, or objects beyond the level area (an issue, if the building has no boundary).
Perhaps one approach worth considering would be to associate each VisualARQ object with a specific level through an object property, assigned automatically based on the active level when the object is created, but editable afterwards.
This would distinguish an object’s level association from its geometric position and level constraints, without relying on viewport visibility or geometric selection.
Such an association could be useful not only for duplicating levels, but also for other BIM workflows, such as selecting or managing objects by level.
Of course, there would still be special cases to handle, but I think this could provide a more consistent foundation.
Yes, this is something we could implement. It’s actually already in our wish-list. But still this would not solve how to duplicate levels and include objects in the copy. Perhaps there should be a specific command for that. Anyway, we need to study it.
Hi, I also second the wish for level property in all VA objects. It would clear up which object is allocated where and it could be used to overwrite default allocation if it does not fit workflow or drawing creation to remove some object from specific levels. For instance if they go through more levels, to choose, which one I want to asign it to, without splitting the wall, or elevator object which could also be native rhino objects, so also consider to apply this levels allocation also to all native Rhino objects. Thanks for considering.
This would also be useful for distinguishing between buildings based on element properties rather than building boundaries. Currently, buildings can only be defined by a boundary. In practice, two buildings can be very close to each other, and their footprints may overlap when projected onto a 2D plan - for example, a building’s boundary at foundation level may differ from its boundary at roof level. A single 2D boundary is therefore not always sufficient to distinguish between buildings for documentation or modeling purposes.
Assigning elements to specific levels within a building would resolve this ambiguity. Building visibility toggles should then respect those assignments rather than rely solely on containment within a 2D polyline boundary.
