Hi…,
my customer writes, he is annoyed, that _Dim is not resetted, after the option _Continue was activated once with _Yes. I see this too.
Please can the standard _Dim buttons be changed to _Continue=_No.
Thanks
Michael
www.flexiCAD.com
Hi…,
Thanks
Michael
www.flexiCAD.com
Hi Michael -
I’m not sure what is being asked for here. The left mouse button action on that button is without continuation.
Apart from that, the Dim
command remembering its options within a session was a frequent user request up to 2015 when that was implemented (RH-31444 - not public).
Hi Wim,
I think 95% of the time _Dim is used with _Continue=_No. When you switch once to _Continue=_Yes, you have always set this back manually with _Continue=_No. This is annoying.
In Rhino 5 the option was set internally allways back to _Continue=_No, but not in Rhino 6 and 7.
Or have I missed something?
Thanks
Michael
Hi Michael -
That is correct. As I wrote, RH-31444 changed this based on numerous requests.
This is the first request to the opposite since 2015. Both are valid; only one can win.
Hi Wim,
you are right, it is fine and consistent that _Dim and all commands remember their last options.
Nethertheless setting things back for most of the cases is annoying. So therefore the solution would be to add _Continue=_No to the standard cases.
Thanks
Michael
Hi Michael -
And I guess, that’s where I get confused. What is the standard case?
Hi Wim,
sure, I count one annoyed customer.
Cheers
Michael
@Michael_Meyer , @wim I do not see any reason not to make the LMB macro explicitly set Continue=No. I should have done this for RH-31444 to begin with.
Wim, shout if you think this would mess existing workflows - I kind of don’t think it would but…
RH-64469 Toolbar: Set dim macros to Continue=No
Thanks, Pascal!
I don’t think that would mess up anything, no. I see that I failed to understand that this was what was being requested here. Sorry about that, Michael.
Hi @pascal,
thank you for adding _Continue=_No. Nethertheless _Dim seams still buggy to me. When I use _Dim _Continue=_Yes in Rhino 7.10, it continues the last created dimension, instead creating a new unlinked dimension.
Please can you take a look.
Thanks
Michael
Hi @Michael_Meyer,
Thanks for the discussion.
I was involved with this debate back in the Rhino 6 beta testing about 5-6 years ago.
It appears there were, and are still two camps here:
I was not sold on this behavior and wrote a bug up in Rhino 6 Beta testing. But the developer was confident that this was the best approach, so I decided to embrace the change with a Keyboard shortcut assigned to F4. It toggles the Dim continue setting and restarts the Dim command.
Keyboard F4: !Dim c Enter Dim
So whenever I start a dimension that is continuing (or not continuing), I tap F4 and I am are good to go.
I am doubtful that after 4 years we will be able to change this back now that many user have adopted the new behavior.
Let me know if this Keyboard shortcut works for you.
There may be a RhinoScript or plugin option that would give you a DIM2 that would duplicate the Rhino 5 Dimension behavior. But you will need to convince @dale to do this.
Sincerely,
Mary Ann Fugier
I am not sure, if we talk about the same thing. Try this:
Do a horizonal continuous dimension with:
! _Dim _Continue=_Yes _Pause _Pause _Horizontal
Then do a vertical continuous dimension with:
! _Dim _Continue=_Yes _Pause _Pause _Vertical
The vertical continuous dimensions (from point 2) stay still horizontal. I get confused.
In my opinion the continuous dimension should have never a link to the last dimension (as lazy person I even can’t remember my last dimension )
Thanks
Michael
Hi Michael,
Thanks for the images and the addition details.
Lazy is good! The path of least resistance is always preferred!
Yes- I see that. I will log a bug.
I also see this:
Do you see this as well?
@pascal Maybe the LMB macros should set the Continue=No for both the Horizonal and Vertical buttons?
Sincerely,
Mary Ann Fugier
I too have found this really annoying. It’s one of the annoyances that sends me back to ACLT for my 2D.
Hi Mary -
@mary
This is what we have now -
! _Dim _Continue=_No _Pause _Pause _Horizontal
! _Dim _Continue=_No _Pause _Pause _Vertical
Does that look correct?
But what Michael describes looks to me like a bug - not a macro problem, is that right?
FWIW, the way Continue currently works looks wrong to me - a new run of the command should always start a new set of dimennsions and you should need the command line option to continue a previous one.
I agree. I will write it up, again.
Thanks,
Mary
@Michael_Meyer, @mary, @pascal, @wim,
I believe this is what is being looked for:
_Dim _Continuous=_Yes _NewChain
Let me know if I am confused.
– Dale
@dale - I would flip it around and never do anything other than start a new chain - in the command. The option would allow continuing an existing one.
That is, @dale , @mary I think I would change the command so that it never automatically continues an existing dimension if Continue=Yes. The only way to continue an existing dimension would be to use the ‘SelectDimensionToConinue’ option.
Yes- I see that @Pascal.
You made these corrections in Rhino 7 Sr9.
One suggestion for those that do not have these updated macros:
Run the ToolbarReset command and restart Rhino.
