often I need to simplify complex production models for visualization use. The command _untrim AllSimilar=Yes is a great helper. A little enhancement could make the command more powerful. Could be added a detail size limit for untrimming?
Here an example - I like to keep the large opening in the panel, but get the small holes closed.
Hi Micha - I can imagine this would be handy - and possibly difficult in the general case but maybe more tractable for planar surfaces - @rajaa - what do you think?
Hi Rajaa - I can imagine area and length might both be useful criteria, but say length for now, and part of UntrimHoles would seem reasonable… to me. Maybe an option: MaxLength=XXX and Zero would be the default, and mean no limit… does that seem OK?
While you are changing that command, wouldn’t it make sense to allow a user to just pick those holes that should be left in place? Command line option ExceptionList or so.
today I used the new feature the first time. Makes fun to use it, the workflow got a boost.
A little wish - if the command is active, could it be possible to type in the detail size without to click on the maxedgelength option before? So like it can be done at the running _filletedge?
