WISH: Connect
You can use the command “Connect” on several curves?
For example, in Rhino 5 if I have 5 lines to connect must run the command as many times, however it would be better that the command was completed successfully when the user decides.
Into one command connect the 5 lines to the Pentagon:
Hi Davide - try
! *_Connect
whoa, what’s that * command prefix?
Hi Andrew- that is a repeater… you can also use Repeat.
rhino continues to astound with little useful secret tricks :slight_smile: (side note though - that one doesn’t work in mac rhino it appears!)
